6530 Turbo Service
/ 6530 Turbo Service #1
RMOMN
Prior Lake, MN
Mahindra 6530,Farmall H,John Deere 620
I have a 2013 6530 and the operators manual doesn't list what needs to be done to service the turbo. Do I need to do anything other then keep the engine oil changed per the manual?
/ 6530 Turbo Service #2
A turbo should not need to be "serviced"
Keys to long turbo life are:
As you mentioned scheduled oil changes.
Let the tractor idle for a few minutes before shutting it down after working it.
The turbo shaft spins on a film of oil. If you shut it down when very hot the turbo will bake the oil in it.
Make sure that your air filter stays clean and does not develop holes that would allow dirt past.
Finally, if you trailer the tractor cover the exhaust. The wind could cause the turbo to spin, and with out the engine running the turbo is not getting lubricated and will wear out quickly.
Thanks Diesel
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
1994 Geo Tracker, 5spd, Soft Top (A62679)
1994 Geo Tracker...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2018 FORD F-350 (A65643)
2018 FORD F-350...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
