6500 4WD rear hyd. leaking down
   / 6500 4WD rear hyd. leaking down #1
awill99
15 acres Celeste
Mahindra 6500 4WD with Skid Steer FEL.Mahindra 3616 HST with Skidsteer, Vermeer RT200 Trencher
35 hours and even with a light weight rear attachment like post hole diggers without auger (maybe 220 lbs) it will drop about 1 ft per 2 hours. FEL is fine. Can find no leaks and fluid is good. Any thoughts?
   / 6500 4WD rear hyd. leaking down #2
Maybe an internal seal?
   / 6500 4WD rear hyd. leaking down #3
I had a similar problem. It eventually got to the point where, with an attachment on back, the draft arms would fall when I used the loader. It turned out that one of the rings (hard plastic) on the draft arms cylinder was flattened (had rolled out of groove). As soon as hydraulic pressure was diverted to the loader (and away from the draft arm) fluid would leak between the cylinder and the cylinder wall.
Bob
   / 6500 4WD rear hyd. leaking down #4
Hey Arnold! I'll bring up your problem at work tomorrow, and see if we can figure anything out. May have to get hands on it. I still have your cell #, I'll give you a call tomorrow. By the way, how you been?
Ty
   / 6500 4WD rear hyd. leaking down #5
warranty!
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2- 30 X 42 TRIANGLE PIPE RACK (A52472)
2- 30 X 42...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
