Tires 6500 4WD Front tire rubbing.
   / 6500 4WD Front tire rubbing. #1
Maine_Polack
Central Maine
Mahindra 6500 4WD
Purchased 6500 4WD, Farmi, and forks w/grapple. It is quite a beast, as shown in the pic. It kinda fills the garage.
Have 11.2x24 R1-Ags. on front. When turning right, the rear rubber of the right will rub on the side of the loader frame that bolts on the side. Same with left turn and tire.
Is there an adjustment to keep from this "oversteering"?
   / 6500 4WD Front tire rubbing. #2
My 6500 4WD has the front tires all the way in and they have not ever rubbed. I'm guessing an adjustment problem. They are close enough so that I did not put chains on the front though.
Will
   / 6500 4WD Front tire rubbing. #3
i wonder if you put barn type doors that swing open to the side if you would have enough clearance to not have to let down your rops every time you go in and out of the garage.
mine clears by 1/2"
   / 6500 4WD Front tire rubbing. #4
read your front end loader owners manual. there is an adjustment on the front axle for that. just a jam nut and bolt on each steering knuckle
Wow!...we are supposed to read those manuals?
Since it involved the tire attached to the tractor, I actually did look in the tractor manual. Never thought to look at the loader one. thanks.
And speaking of manuals....the "00" series manual that I received is some impressive. The pictures - color and very clear - are excellent.
2015 CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
New Hydraulic Oil Tank With Site Gauge and Filter (A47384)
New Hydraulic Oil...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2020 CATERPILLAR 308CR EXCAVATOR (A51242)
2020 CATERPILLAR...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
Hydraulic and Coolant Radiator With Hydraulic Driven Fans (A47384)
Hydraulic and...
