65 Massey engine timing.
   / 65 Massey engine timing.
Yeah I understand.. Like I said, that was the absolute 1st time I've seen that on a CAV/Delphi pump & I've been doing this for a VERY long time..
Its also intersesting that U KNEW the drive plate letter.. & it wasn't given in the test/calibration spec sheet..
There was a service bulletin along time ago stating that MF no longer requires CAV/Delphi to add the drive plate letter in their spec sheet..
BUT "I" always set it anyway.. just incase the mechanic had lined it up when he pulled it off {timed it}..
It would be an unwanted/uncalled for mess if the pump was timed w/ the drive plate letter & it wasn't set after a rebuild..
& the customer "TRIED" to time it using the out of place C-Clip..
Good luck w/ your project.. & comeback & let us know how u made out & IF in-fact the gear moved.??
I知 only guessing at the actual drive plate letters. The letters I致e guessed were provided in the manuals I have. Here痴 to hoping the letters are the same!
   / 65 Massey engine timing. #12
I'm pulln' for ya.!!!
I know the gears are "captured" on most Fords..
Not so sure on a MF..
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
2013 Ford Expedition 4x4 SUV (A49461)
2013 Ford...
2011 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2011 MACK GU713...
Craftsman YTS 3000 42in. Riding Mower (A49346)
Craftsman YTS 3000...
PALLET OF HYDRAULIC HOSES (A50854)
PALLET OF...
