6430 Premium power beyond options
   / 6430 Premium power beyond options #1
OrangeJbird
NW WI
3320 w/300cx FEL
Can I use these ports for power beyond for mid mount loader valves or do I have to add a block to the rear scv bank?
2011 with IVT and TLS
   / 6430 Premium power beyond options #2
Do you have the service tech manual for the 6430?
I do not have service manual.
Just acquired the tractor recently.
I’m aware there’s a ton of knowledgeable folks here.
Thought I’d ask.
   / 6430 Premium power beyond options #4
One problem with asking. You never know if you can trust the answers. That model is one that was offered with both open center and closed center hydraulics. It's best that both parties know which system is under discussion.
   / 6430 Premium power beyond options #5
I'm not a JD man but you should have what is called a "closed-center pressure and flow compensated (PFC)" hydraulic system.
You can not use a standard open center valve on your tractor you will need a a pressure sensing control valve plumbed into your system
It is closed-center pressure and flow compensated (PFC) And I know what I need for loader valving. I only want to know about the question in my original post.
HYD AUGER W/ 10" BIT (A52708)
HYD AUGER W/ 10"...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
2019 Berky Weedo Amphi King 6450 Amphibious Workboat (A56857)
2019 Berky Weedo...
1604 (A57192)
1604 (A57192)
