6430 Premium Hydraulic Quick Connector Problem
/ 6430 Premium Hydraulic Quick Connector Problem #1
tuckahoefarmer
Ivanhoe, NC
JD 6430
I have a JD 6430 Premium that was purchased new. Every so often one of the hydraulic quick connectors of the rear will blow the hose out of it and puke oil. This usually makes the connect beside of it do the same thing. I have replaced 10 or 12 of the connectors in the 5600 hours of operation. When connected the lock ring snaps back into position as it should. Anyone have a problem like this?
Thanks for any light you can shed on this subject.
Bill
/ 6430 Premium Hydraulic Quick Connector Problem #2
I have a JD 6430 Premium that was purchased new. Every so often one of the hydraulic quick connectors of the rear will blow the hose out of it and puke oil. This usually makes the connect beside of it do the same thing. I have replaced 10 or 12 of the connectors in the 5600 hours of operation. When connected the lock ring snaps back into position as it should. Anyone have a problem like this? Thanks for any light you can shed on this subject. Bill
When you say connectors, do you mean on the hose side or tractor side? Not familiar with that exact model but there should be some springs on the tractor side that can be replaced. However if both hoses are blowing out sounds more like the return side is not giving relief at times during operation.
/ 6430 Premium Hydraulic Quick Connector Problem #3
I have had trouble with the "Premium" couplers. Ones that do not have the locking sleeve. You just push the male in and some hellishly complicated system (there is like a dozen O rings) keeps it in, but sometimes it just spits it out. I would gladly have the simple ones. Just another "GREAT" and progressive idea brought to you by the wonderful Engineers at JD. They also come with a wonderful price!
OXBO CP100 - 1R SWEET CORN HARVESTER (A63291)
OXBO CP100 - 1R...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
UNUSED WOLVERINE SB66-66" ROCK BKT (A64281)
UNUSED WOLVERINE...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
UNUSED WOLVERINE (A64281)
UNUSED WOLVERINE...
