6420 IVT - Any Comments
/ 6420 IVT - Any Comments #1
JD9610
G'day from Australia
I am looking buying the new 6420 with IVT. Does anyone have one and what is it like?
I am mainly using it for spraying at 15 mph so am also looking at the suspended front axle and cab suspension.
What do you all reckon?
/ 6420 IVT - Any Comments #2
They are really nice. Way smoother driving than the JD powershifts. I have driven the IVT's many times at work mainly on the 7920. I like it because they still give you a clutch so you can start and stop with that plus the reverser lever on the side of the steering wheel to change direction. It would be a great trans for spraying since you can go any speed you need. Not to fast or too slow.
/ 6420 IVT - Any Comments #3
I've got a 6415 which so far has been rock solid. It's pretty much the same tractor as the 6420 except the 6420 has a nicer cab. I've also got the 8320 with the IVT. The IVT is very nice. Very smooth. All the benefits of a gear transmission but IV speed. We use the 8320 for alot of spraying and no problems at all.
/ 6420 IVT - Any Comments #4
Hmmmm.............might want to look for an opinion from Euro land on these. Not too many of the 4 cylinder shiftless tractors around North America as of yet. Try over at www.agmachinery.tk or www.fwi.co.uk for answers. The feedback I've heard so far about the ZF EccomII in the Deere tractors is that it is much easier to use than the Vario,especially for occassional users.
/ 6420 IVT - Any Comments #5
A clutch on a shiftless tranny? Now I've never driven one yet myself,but I've also never seen or even heard of a clutch on a CVT equipped tractor either. Are you sure it is a clutch? More than likely it is what is known as an "Inching Pedal".
/ 6420 IVT - Any Comments #6
hey Doc,
I gots a question...........Either you made the same typo twice about having a 8320 with IVT.......or you are a Deere guinea pig with a IVT equipped 8030 series in 8320 clothing...........Or Deere is now sticking the IVT into the 8020s and is doing it covertly........?
/ 6420 IVT - Any Comments #7
Well, it's probably not a clutch but if you were a farmer for many years you would be reaching for a clutch so JD put a pedal that you can depress to stop the machine and coast just as if you pushed the clutch on a gear drive. Also they give you split brakes too.
Thanks everyone for your advice.....
All the best from Aus.
Case 2090 Tractor (A66285)
Case 2090 Tractor...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
Unverferth 330 (A64119)
Unverferth 330...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2004 John Deere 4720 (A60462)
2004 John Deere...
