6410 pumping Hyd oil out top of rear end
   / 6410 pumping Hyd oil out top of rear end #1
atc007
jd 6410,3255,2950,2940,lots of Masseys : )
340 original hours. Anyone know what this is and how to fix it? Standing behind, looking in over top right arm just in under cab. TY so much and may God bless you and yours.
   / 6410 pumping Hyd oil out top of rear end #2
I’m a little disoriented looking at your picture. I see some kind of fitting or hydraulic cylinder that looks bent. I can’t tell for sure.
Other thoughts. Is the hydraulic fluid overfilled? Is it getting to hot?
   / 6410 pumping Hyd oil out top of rear end #3
I'd get me a new seat or find better diapers.
   / 6410 pumping Hyd oil out top of rear end #4
I agree with Dodge Man I cannot make heads or tails of the picture.
I have found that when fluid gets too low you can begin to add air to the fluid causing foaming, thus expanding the volume of fluid.
   / 6410 pumping Hyd oil out top of rear end #5
On another forum it was pointed out a hose clamp is missing. I think what I saw when I first looked is a hose on the right, mostly painted green, and the fitting on the left that the hose slid off.
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
City of Lakeland (A51691)
City of Lakeland...
53ft trailer Vin IUY VS2532 7M0152 01 VS2RA (A51694)
53ft trailer Vin...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
JOHN DEERE 2038R LOT NUMBER 175 (A53084)
JOHN DEERE 2038R...
