6410 pto spline shaft broke
   / 6410 pto spline shaft broke #1
deerefan
louisiana
1952 8N, 2005 JD 5103
See picture. Is this an easy repair? Do i just remove the snap ring like a 4020?
   / 6410 pto spline shaft broke #2
Is your tractors pto 540 only or 540/1000 rpm???? Dual pto is easy to change very similar to 4020. Single speed pto is more complicated.
Dual pto. We got it out. It used something like a spring loaded locking collar
   / 6410 pto spline shaft broke #4
How did it break?
Zebrafive said:
How did it break?
I am not exactly sure but we suspect it was done using a bushhog with incorrect shaft length. It broke while bushhogging.
   / 6410 pto spline shaft broke #6
Have bought a new shaft yet? If not, there is one on ebay for $50 shipped
Yes were in a jam and needed one pretty quick. Local jd dealer had one.
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
2012 MACK GU713 DAYCAB (INOPERABLE) (A53843)
2012 MACK GU713...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2012 LEEBOY 8515B ASPHALT PAVER (A51406)
2012 LEEBOY 8515B...
