6400 Torsional Dampener Issues!!
   / 6400 Torsional Dampener Issues!! #1
mastercraftka
Hondo Texas
1993 JD 6400 4wd
We have a 6400 and one day I was moving a bale of hay and I lost hydraulics light came on and I started to get smoke from under the cab. Upon inspection i noticed that the smoke was coming from what you see in the picture. So I know nothing about this and what it does. What am I up against and what does it do?
   / 6400 Torsional Dampener Issues!! #2
6400 parts catalog shows a serial # break @ <120756 for torsion damper utilized with PQ trans. AL79074 @ $1300.
Dampener helps absorb shock loads when changing gears or tractor directions.
Ok it must be more serious than a piece of rubber then because we have no tranny or remotes.
   / 6400 Torsional Dampener Issues!! #4
No trans or hyd's indicates damper has failed!
How big a job is that replacement?
I know one thing you don't want to get that black goo on you!! It don't come off very well.
   / 6400 Torsional Dampener Issues!! #9
I guess I own one of those. Who knew? I got my PQ used, I hope this part is good for a while.
Makes no sense to me from what I can see, why this would disable the movement of the machine.
   / 6400 Torsional Dampener Issues!! #10
ya I thought that was it but now figuring out how to replacement.
I PMed you....It sounds like you remove the right rear wheel and tilt the cab to the left after disconnecting the clutch and throttle cables etc.
(2) GMC Top Kick Transmissions (A54865)
(2) GMC Top Kick...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
ITEM LOCATION (A53084)
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2024 CATERPILLAR 299D3 SKID STEER (A52706)
2024 CATERPILLAR...
