6400 PTO Stalling under load
/ 6400 PTO Stalling under load #1
JW IN VA
Ford 6640,5000,4600,7600,861
Title says it all.PTO works without machinery attached.Not my tractor but trying to help a guy out.
/ 6400 PTO Stalling under load #2
Check pto hyd pressure. Sounds as if clutch plates are slipping due to insufficient hyd pressure
/ 6400 PTO Stalling under load #3
Could be low pressure as TxJim suggests, or could be worn 540/1000 shift linkage internally. If tractor is equipped with 540/1000 option. What pto speed are you trying to use? 1000 rpm rarely has problem, 540 can have worn parts that won't allow full engagement of gears. Sometimes installing a new snap ring to hold pto shaft in can give enough engagement to allow pto to work for a while. May need to remove rear pto housing to replace worn parts.
Thank you.He has decided to send it to the dealer.Probably best option for him.
/ 6400 PTO Stalling under load #5
I know the owner is sending it to the dealer but FYI mine was doing that and it turned out to be the PTO lever adjustment.
Thanks .Will pass along.
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
5ft Frontier Rotary Cutter (A65579)
5ft Frontier...
2019 C&M TRAILER 16' COOL DOWN TRAILER (A65643)
2019 C&M TRAILER...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A64556)
2019 Chevrolet...
