6400 jerky clutch
   / 6400 jerky clutch #1
stoneridgemb
ste rose
allis 7040
this is a JD 6400 fwa, power quad with right hand reverser. Just as the clutch is about to engage, the tractor jerks forward. it had a broken spring in the modulation valve and I also changed the piston but it did not solve the problem. If I quickly release the clutch the tractor pulls away smoothly. what do I look at next?
   / 6400 jerky clutch #2
Suggest reposting or asking a moderator to move your post to "John Deere AG Tractors" so the JD guy will see it.
   / 6400 jerky clutch #3
A buddy of mine had the same problem on his 5400 2wd 4-5 years ago. After contacting the local independent JD mechanic, he told him it was more than likely the clutch pack needing replaced. Not from wear, but from rust/corrosion in the clutch pack not letting all the plates and disc's release evenly, causing the tractor jerk, when releasing the clutch pedal. As I understand, your not able to rebuild the clutch pack, so a new unit is required.
Being my buddy was working a lot of overtime at that time, he decided to let that mechanic do the work. I don't recall the total bill, but remember the clutch pack was around $650 at the time.
378661 (A51573)
378661 (A51573)
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2019 INTERNATIONAL LT625 (A52472)
2019 INTERNATIONAL...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
