64 Case 530 CK
   / 64 Case 530 CK #1
67Mopar
Mass
Case 530
Hi I pulled the carb off, it was leaking gas so I figure its a good time to clean it up and check the N&S and see if the float has any rot holes. In any event its a 13106 Zenith, now all apps show that to be for a 580 Case Now I have had this for 4 yrs, but it is possible it was replaced yrs ago etc. Is there a rebuild kit for this carb, new N&S, Float, and Gasket. Also does anyone know if the t on the needle is supposed to have a spring on it, mine does not, and seems sloppy. Finally are these like most carbs bring in all the screws and back them out 2 turns and fire it up? My Needle seems to be out about 5-7 turns. Thanks
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
UNUSED SWICT 60" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 60"...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F550...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
Bush Hog 176 3 pt Blade (A50514)
Bush Hog 176 3 pt...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52128)
2022 Gravely...
