6320 Hyd return
   / 6320 Hyd return #1
Robertb
Hi . does anyone know where to connect free Hydraulic return on 6000 20 series . i am running hyd motors that need free return (not through remotes). 6000 10 series has a port but 20 series have changed ! Any thoughts ?
regards
Rob.B
   / 6320 Hyd return #2
They should have the new "power beyond" kit that has the regular loop that intercepts the full pressure line from the pump to the rockshaft. Plus it has a third line that dumps directly to the sump. That third port is where you want to connect your open return.
I have seen this on 3x20,4x30 and 5x20 so I am assuming it is the same for the 6x20.
   / 6320 Hyd return #3
Can you tell me where the 3rd port on 3x20 enters the sump? I have no power beyond but need to run a zero restriction return on my Clemens weeder. I can't find pictures anywhere.
   / 6320 Hyd return #4
regards
Rob.B
On your rockshaft valve, as viewed from the back of the tractor, you want the right port. It has Plug Key 1 and O-ring key 2 in the drawing.
LINDE WELDER (A53843)
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A54313)
2017 FREIGHTLINER...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
7033 (A51691)
7033 (A51691)
1998 WABA Van Trailer (A53117)
1998 WABA Van...
