6310 cv failure
/ 6310 cv failure #1
Robertb
We have had the CV joint between the engine and transmission fail on both our 6310 tractors. One tractor has failed twice! Has anyone else had the same problem?John deere have replaced the failed cv joint but its non greasable ? Any opinions?
Regards
Robert
/ 6310 cv failure #2
Universal joint? You've had 3 fail?? I'd say it is the replacement part at fault. I find it hard to believe two tractors would have the same problem.
/ 6310 cv failure
Thanks ,I have spoken to others and its a very common problem . the universal joint costs $1300 aus plus fitting costs, cab needs to be tilted over. I am looking at manufacturing a grease able joint to suit. One of 6310 tractors broke the universal joint and it damaged the aluminium transmission costing $11,000 to repair. Any Ideas on this would be greatly appreciated.....
/ 6310 cv failure #4
Robert,
As bad as it sounds, if I had your tractor I would be looking at trading it in on something else.
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2007 Acura TSX Sedan (A61569)
2007 Acura TSX...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2004 STERLING L9500 MIXER TRUCK (INOPERABLE) (A60736)
2004 STERLING...
1667 (A57192)
1667 (A57192)
