6300 - Air Conditioner Fan In Cab Not Working
   / 6300 - Air Conditioner Fan In Cab Not Working #1
JD5210
Virginia
5210 MFWD
My neighbors dad has a 1993 cab 6300. In talking with his dad, he said the fan in the cab for the air conditioner was not working. He said if he jumps the relay (I do not know which one) it works. He said he has replaced the relay and it still does not work.
Not much to go on, but thought I would see, if anyone had any ideas.
Does anyone have a wiring diagram for a cab 6300?
   / 6300 - Air Conditioner Fan In Cab Not Working #2
Power or ground side switches, are used to turn relay on and off. Check all fuses and ground connections, or may have a blower resistor that went bad. Most relays will have a wire diagram on them.
Thanks, I will share you response with my neighbors dad.
   / 6300 - Air Conditioner Fan In Cab Not Working #4
My A/C went out on my Massey Ferguson cab last year with the exact sounding problem. I also jumped the relay and it worked. Replaced the relay and it worked for a week then blow again. Called and talked with a good mechanic friend who referred me to a guy that works with auto A/Cs who had the same responds as my friend. After describing my problem they both said it was the blower motor. I replaced it ($230) and have been cool since. For what it's worth...
John Deere 7130 (A50120)
John Deere 7130...
Wolverine Mini Skid Steer Stump Grapple (A50515)
Wolverine Mini...
2013 Hyundai Azera Sedan (A50324)
2013 Hyundai Azera...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
2005 Sterling Semi (A50514)
2005 Sterling Semi...
400 bu Gravity Wagon (A50514)
400 bu Gravity...
