62D which Gator blades?
   / 62D which Gator blades? #1
Deadman
WI
John Deere 2520, X475
I know there are numerous different styles and manufacturers of these Gator blades with different lifts, teeth, etc. What ones have the most lift and mow the best on a 62D? The heavy Oregon ones?
Just want to be sure I order the right ones! I'll be mowing taller turf grass, weeds, etc so I need a blade with a little lift and the teeth to shred the longer clippings!
Thanks in advance! :thumbsup:
   / 62D which Gator blades? #3
IIRC - there was only one set for the 62D.. at least when i ordered mine years ago.. they are technically listed under the 62C mower deck and are the 'magnum'
brian
   / 62D which Gator blades? #4
If you want to use Gator blades, the Oregon G5 and G6 are the best out there, and are real Gator blades. They are identical in every way except for thickness. The G6 is .250" thick, and the G5 is .203" thick.
The G6 for the 62" deck is part # 396-771
The G5 for the 62" deck is part # 596-771
Both are direct replacement for OEM part # M143504
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
