62D, Independent lift cutting height adjustment questions.
   / 62D, Independent lift cutting height adjustment questions.
Ok, thanks for the ideas.
I normally cut "higher", so the wheels are adjusted properly for the height I mow at, but I figured letting the deck go down farther would be good for the video of the lifting and lowering of the deck.
The adjuster just really sucks, as far as the accuracy of it. I wish there was an easier way to "calibrate" it, so I could figure out what height each notch cuts at and mark it and then not have to check it every single time I readjust the mower height knob. I'm sure I'll figure out a way, but my gosh the mechanical lift I had on my 2520 was just so much more accurate and simple.
i'm really amazed how sloppy this independent lift is compared to the mechanical lift kit. My mechanical lift held the mow deck in place snugly and the deck didn't slop from side to side when on obstacles and such. This independent lift allows some sloppiness and it makes trimming a slight challenge. its not exactly sloppy, but in comparison to the mechanical lift it sure is. Oh well, it works fine!
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
2010 JOHN DEERE 310J BACKHOE (A52709)
2010 JOHN DEERE...
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A58017)
2020 INTERNATIONAL...
2015 MACK CXU CONVERTED TANDEM AXLE DUMP TRUCK (A58017)
2015 MACK CXU...
