62D Deck on a 2305
   / 62D Deck on a 2305 #1
wsp617
Wisconsin
JD 1070
I have a 2305 with the 54" deck. A buddy of mine has a 2520 with the 62D drive-over deck. In just looking at it, I was thinking it would fit on my 2305. He's looking to sell the deck because he's gone to mowing with a zero-turn mower. Anyone else know if this would work?
   / 62D Deck on a 2305 #2
The only way to know if it fits for sure is to try it. That should be easy for you since your friend has the deck.
My guess is the the front hangers & pto shafts are different, but you may be able to swap those from your 54" deck. The gear boxes could also be in a different locations.
   / 62D Deck on a 2305 #3
Your 2305 is a sub compact and the 2520 is not, (it is a compact which is a larger frame size).
Your best hope is, when you try it, that all the brackets used for the 62D on the 2520 will bolt up to your 2305. Some measuring may give this info and worth a shot.
As the frames are different, I doubt it would work.
Hope you let us know how it goes.
   / 62D Deck on a 2305 #4
I think the pto on the tractors are different. One is to the right of the center of the tractor and the other is to the left of center.
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
Wacker Neuson TH522 Telehandler (A50860)
Wacker Neuson...
2018 Dodge RAM 3500 Truck W/Dump Bed (A50860)
2018 Dodge RAM...
Poulen Pro 6000 Watt Power Generator (A50860)
Poulen Pro 6000...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
