62" MMM question
/ 62" MMM question #1
rvtech
Sunbury, Ohio, U.S.A.
2006 John Deere 2305
62\" MMM question
I have a noise in my MMM when I make a hard right turn. It sounds like a blade scrapes. You can also feel a vibration at the same time. I have pulled the mower twice and looked at blades, belt and pulleys. The only thing I see is some slight wear on the plastic belt cover. The deck has no marks or paint missing. It only does it with the mower running. It does not do it at very slow speeds (crawl) and it doesn't do it unless it's turned nearly all the way to the stop. I noticed it soon after new but it seems to be more frequent now.
Any ideas?
/ 62" MMM question #2
Re: 62\" MMM question
maybe check the belt tension.and check for belt wear if you havent already
/ 62" MMM question #3
rv,
I also get a bit of a vibration when I turn right at the limit of travel. It makes the spring on the anti-scalp wheels chatter/vibrate. I just chalked it up to the powersteering fighting the limit. Let us know if you find out otherwise. /forums/images/graemlins/tongue.gif
/ 62" MMM question #4
JDFAN
The wheels were the first thing that I thought of. I had that problem with my 62 deck. If you don't have them adjusted right they make a real racked & vibrate on turns. At times it will sound like a blade hitting the ground. Adjusting the wheels would be the first thing I do, it’s an easy enough adjustment.
2005-2210 --200CX 53" FEL, 62c MMM, 47" Two Stage Snow Blower, 48" Tiller, Speeco PHD, 5' back Blade, I-match Hitch, ballast, and PTO driven model 854 TRAC VAC
JD Deere 140 H-1
JD Deere 140 H-3
/ 62" MMM question #5
check for twigs and debris rubbing the belt. I actually had a bit of a twig stuck in the v of a pulley causing vibration to the belt. also check the universal joints.
/ 62" MMM question
I'm going to check all adjustments when I put the deck back on. I recently received the owners manual from my dealer because they were out at the time of delivery.
I did already check the belt and removed the cover to check pulleys and for debris. I didn't see anything wrong on top or underneath.
/ 62" MMM question #7
This may sound simple and stupid, but carefully inspect the inside sidewalls of all four tires to see if anything has been catching and rubbing them in turns.
/ 62" MMM question #8
With a hard right turn your front tire may be hitting the pin that holds the mmm front bracket on the frame. It is a commom problem if the dealer installs the wrong pin. it should be an L shaped pin.
/ 62" MMM question #9
In my case the vibration is not caused from contact with anything I can see (I have the L shaped pins). When you turn the wheel all the way to either extreme, the powersteering will "fight" it, much the same as when you engage 4WD and this "condition" is worsened. I just think the "fighting" of it introduces a slight vibration (you can feel it in the seat of your pants) and this is transferred to the pins which are just spring-loaded. /forums/images/graemlins/tongue.gif
/ 62" MMM question
Mine only does it with the mower engaged so I don't think it is anything in the front rubbing. I think it has to be something in the mower.
One thing to add. It doesn't do it unless the mower is down. I have mowed some of my high grass with the mower up and it does not make the noise or vibration.
/ 62" MMM question #11
rv,
I think you are describing something else. If it only does it when the deck is lowered, then it seems like it would be the wheels, or perhaps something in the suspension linkage. /forums/images/graemlins/blush.gif
/ 62" MMM question #12
RV,
Have you tried to reproduce it with the gauge wheels in the highest position to eliminate them as possible cause? When they contact the ground during a tight turn it will get your attention. Another idea would be to try and reproduce it on a flat level surface, i.e. cement, blacktop, etc.
dsb
/ 62" MMM question
I'll have to try a few things when I put the deck back on. I'm sure I'll figure it out. I thought maybe someone else has already seen the problem and had a solution.
I'm busy the last few days running the backhoe. We've had a nice warm up here and I'm not wasting any time. I dug 2 trenches today. The mower will have to wait until I'm done digging. /forums/images/graemlins/grin.gif
/ 62" MMM question #14
rv,
Not to get sidetracked from this post, but, how is the BH working out for you? More descriptive posts are begged for! /forums/images/graemlins/tongue.gif
2010 Chevrolet HHR SUV (A61574)
2010 Chevrolet HHR...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2018 Kia Soul SUV (A61574)
2018 Kia Soul SUV...
GRAVITY BOX (A63291)
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
