6180 puking coolant out the overflow
   / 6180 puking coolant out the overflow #1
DIESAHL
shippensburg PA
Massey 6180, and a 5520 john deere
have a 6180 that when we run it it will puke out coolant. changed the t-stats and still does it.
   / 6180 puking coolant out the overflow #2
Try replacing the radiator cap and clean out the radiator air passages.
   / 6180 puking coolant out the overflow #3
If you have access to a pressure tester I would try that.
   / 6180 puking coolant out the overflow #4
Check your manual to see what lbs radiator cap it should have. It may require more backpressure on the cap. On my 135 it's 7 lbs.
   / 6180 puking coolant out the overflow #5
I agree with Wacky, pressure test, it could find problems that you can't see from the outside of the motor.
   / 6180 puking coolant out the overflow #6
Hi,
How do you like your 6180? Am looking to purchase a 96' model. Any pros and cons on the tractor? thanks
   / 6180 puking coolant out the overflow #7
Going back to the OP (and 2+ years), was that problem by any chance a blown head gasket? Just curious.
2018 John Deere 8270R MFWD Tractor (A53342)
2018 John Deere...
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A51247)
UNUSED AGT YSRT14...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2015 FREIGHTLINER...
2014 Club Car Electric Utility Cart (A51691)
2014 Club Car...
