6180 puking coolant out the overflow
   / 6180 puking coolant out the overflow #1
DIESAHL
shippensburg PA
Massey 6180, and a 5520 john deere
have a 6180 that when we run it it will puke out coolant. changed the t-stats and still does it.
   / 6180 puking coolant out the overflow #2
Try replacing the radiator cap and clean out the radiator air passages.
   / 6180 puking coolant out the overflow #3
If you have access to a pressure tester I would try that.
   / 6180 puking coolant out the overflow #4
Check your manual to see what lbs radiator cap it should have. It may require more backpressure on the cap. On my 135 it's 7 lbs.
   / 6180 puking coolant out the overflow #5
I agree with Wacky, pressure test, it could find problems that you can't see from the outside of the motor.
   / 6180 puking coolant out the overflow #6
Hi,
How do you like your 6180? Am looking to purchase a 96' model. Any pros and cons on the tractor? thanks
   / 6180 puking coolant out the overflow #7
Going back to the OP (and 2+ years), was that problem by any chance a blown head gasket? Just curious.
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
UNUSED CFG INDUSTRIAL MX20R EXCAVATOR (A51247)
UNUSED CFG...
24in Tractor Backhoe Bucket BT4555 (A53472)
24in Tractor...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
