6110 C belt tensioner bearing
   / 6110 C belt tensioner bearing #1
FrankJohnson
Donie
Mahindra 6110c and 6530
Hello All, i have a 2014 6110 C with 122 hrs, and the bearing to the ac belt tensioner ate itself. anyone have an online resource for small parts. looks like i should replace the idler also. any help is appreciated.
   / 6110 C belt tensioner bearing #2
Warranty work?
Yeah, it probably is under warranty, but its just a bearing and cant be that much. the dealer is 40+ miles away and i have to work. So i figured if there is an online source i'll just have it delivered here an i'm back in business.
   / 6110 C belt tensioner bearing #4
You can order it off any dealer website that offeres parts.
Heres ours
j5tractors.com
   / 6110 C belt tensioner bearing #5
Go ahead and get a spare... I usually order the mounting asmbly with it too.. 6110s had a lot of not updates for say but different set ups tossed out there so iv found you can order the tension bearing and the bolt hole not be the same as before
Ha, found it a short while ago. Just talked to Nathan also. He's working on it. Thanks. The part look up is very helpful.
   / 6110 C belt tensioner bearing #7
Good deal anytime
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
John Deere Z915E Zero Turn (A51573)
John Deere Z915E...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
