610 bobcat sheave
/ 610 bobcat sheave #1
oldfarm
I bought an older 610 bobcat and I'm trying to fix a hydraulic leak behind the sheave. I got half of the sheave off. The other half is still on the drive shaft that I cant get off and it broke it using a pulley puller. Does anyone know how to take it off and get a new one to replace it.
Thank you,
/ 610 bobcat sheave #2
You have to remove the hydraulic swivel, and the piston. Behind all of that inside the sheave is a bolt that threads right into the end of the engine's crankshaft.
You can get a new one... about $350 if I recall correctly.
I would be interested in the old one if you go that route. I need several internal parts.
Mike Danford, 423 580 1383, near Chattanooga TN
/ 610 bobcat sheave #3
just wondering if you know where i can get a seal kit for the variable sheave and maybe the part numbers?
thanks jim
2017 DITCH WITCH JT20 HORIZONTAL DRILL (A63276)
2017 DITCH WITCH...
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A64557)
2020 23 Ft...
2019 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2019 INTERNATIONAL...
2002 INTERNATIONAL 4300 S/A (A67148)
2002 INTERNATIONAL...
2022 KUBOTA SVL75-2 SKID STEER (A65053)
2022 KUBOTA...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2008 Ford F-250...
