plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,394
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I'm expecting to soon purchase a 60hp tractor and skidding winch. Some basic research shows using a tractor for logging activity is very dangerous work. I'd like to learn more of the risks?
So far, I've read about skidding cables snapping, short logs being dragged behind a tractor hitting a stump then going end-over-end into a tractor, logs being dragged downhil turning into missiles that exceeds the tractor's braking capability, having a tire hit a hidden rock that flips the tractor, and more. Plus of course the usual problems of maybe tipping over from side slope or something as simple as getting your hand pinched.
I have no experience with skidding and logging work. My only tractor experience is owning a SCUT for a year, doing loader work and mowing. I keep people away when mowing and keep the bucket low to the ground when loaded. I do have a good background with safely operating mechanical items and machinery-- I am a commercial pilot with a multi-engine and seaplane rating, and have flown small aircraft over several decades to most of the states in the USA with no incident. In lots of different weather and terrain.
I'm hesitant a bit about taking on a high risk activity. But not yet dissuaded from venturing into this. I need the work to be done, whether me or another, as it helps reduce some tree disease from spreading. Fortunately the log mess I need to clean up is relatively flat, with good access from the periphery. And the route to a wide, flat area I would drag logs to is just a very gentle downslope with little or no side-to-side slope.
What other risks do you know of or have you encountered?
