601 ford
   / 601 ford #1
Mitch2144
Trenton Fla
53 601 ford
My lift arms came up, while i was Bushhogging. They wont go back down unless i shut the tractor off. But when the tractor is started up again, they come back up, and wont go down, even with the lift lever all the way down. Any Help would be appreciated. Thanks.
   / 601 ford #2
Sounds like the control valve is stuck you need to remove the lifpt cover to fix
   / 601 ford #4
i agree.. classic sticky unloader valve.
while you have the top cover off.. check oil.. if dirty.. flush sump and change hyd oil.
ps.. top cover gasket and oring kit is a paltry 15$ at your dealer..
   / 601 ford
Thanks Soundguy. Do you know what oil goes in there? iI will prolly go ahead and change it. Thanks.
   / 601 ford #6
i reccomend utf fluid meeting the m2c134 spec ( walmart, tsc, napa, car quest, etc.. all have house utf oils. check pail for spec.. most run 30-50$ per 5g. ) takes 8qts in hyds nominally. will hold up to 4 qts more -if- you use external hyds..
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
2012 MACK WINCH TRUCK (A53843)
2012 MACK WINCH...
John Deere 333E (A47477)
John Deere 333E...
5TH WHEEL TRUCK TOTE (A53843)
5TH WHEEL TRUCK...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
