6000 4WD HELP!! Stuck Clutch/Safety Switch
/ 6000 4WD HELP!! Stuck Clutch/Safety Switch #1
medicpelle
JD 1020, JD3040
I have a 05 6000 4wd with a stuck clutch, pulled the inspection plate off to find a significant amount of rust after sitting for a few months. I can't get it off the flywheel. I attempted to jump what I believe to be the neutral safety switch located on the right side under the step/wheel well area. I could not get the switch to jump to start the tractor in a high gear to attempt to unstick the clutch. Is this the right area for the switch? any help would be greatly appreciated.
