600 series rotor clip question
   / 600 series rotor clip question #1
klink
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
I have a 660 Ford [600 series] I have only owned this tractor for 3 years and don't know the history - I recently replaced the distributor cap and rotor - the old rotor had a little medal clip that went in side the rotor shaft hole. I tried to put the clip into the new rotor, but could not see how it fit in the new rotor - here's my question - Do I really need the little metal clip? the old rotor seemed to be messed up in the shaft hole. I thought maybe the newer rotors don't need the metal clip?? Maybe someone can enlighten me on this subject. Pic is of the old rotor
klink
   / 600 series rotor clip question #2
You need the clip. Put your dust cover on than put the clip on the shaft, not in the rotor, than put your rotor on and dizzy cap.
Kirk
   / 600 series rotor clip question #3
You need the clip. Put your dust cover on than put the clip on the shaft, not in the rotor, than put your rotor on and dizzy cap. Kirk
My buddy kept having rough running issues until I told him about the missing clip. Without the clip your rotor has too much slop.
Thanks for clearing this up in my mind - I guess I was doing the wrong procedure Thanks again
klink
Yesterday, I took the distributor cap back off and reassembled the dust cover - put little metal clip on shaft - put rotor on shaft - put Cap back on - snapped in the two cap retainer clips - checked firing order. I did that about 2 times until I realized that the dust cover was sitting on top of the condenser wire, thus was not seating in properly. after that everything went well. I'm sure glad I got that all corrected before club tractor ride. Thanks to all of you.
klink
   / 600 series rotor clip question #6
7$ clip too, dont loose it or you will have to replace it with 1cent of masking tape ;)
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2021 Harley-Davidson FLHP Police Electra Glide Motorcycle (A51694)
2021...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
