60" MMM Spindle Disassembly
/ 60" MMM Spindle Disassembly #1
DSM
PA
Kubota BX22
60\" MMM Spindle Disassembly
Does anyone know how to take off the bottom flange (under the deck) of the center spindle on the BX 60" mower deck? Does the gearbox have to be disassembled? Removing the 4 bolts doesn't do it.
/ 60" MMM Spindle Disassembly #2
Re: 60\" MMM Spindle Disassembly
Haven't had to disassemble a MMM as of yet so I can't help in that regard but you can request & recieve an illustrated parts breakdown from TractorSmart.com which may help.
TractorSmart
Good luck.
Volfandt
/ 60" MMM Spindle Disassembly #3
IF you are talking about that cone shaped piece on the shaft just above the blade, here's how. Remove the blade. Take a small pocketknife blade or something with a small pointed tip, and scrape all the dried out muck out of the circular groove between this flange and the area around it. I couldn't get mine off this past Saturday because pulverized wet starch from grass had gotten into the space and dried into a virtual cement. Scrape it all out while continuing to rotate the flange. Eventually it will slide right off. IF your'e inquiring about some other part, I apologize for misunderstanding your question.
CHEVY 4X4 DUALLY TRUCK BED (A63569)
CHEVY 4X4 DUALLY...
Four (4) Firestone Combine 520/85R42 Tires (A63116)
Four (4) Firestone...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Ford F800 (A63118)
Ford F800 (A63118)
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
