60 MMM DECK ON BX 22 (HOT)
   / 60 MMM DECK ON BX 22 (HOT) #1
LOUIE44
northville , mich
BX22
Can any one tell me how hot to the touch the
gearcase is on their mmm after using it.
my seem quite hot , is this normal?
   / 60 MMM DECK ON BX 22 (HOT) #2
Well I must admit I never touched mine after mowing but a sealed gearbox that small that is air cooled and spinning as fast as it does will be pretty hot. Keep this in mind as well. Your hydraulic fluid that powers your HST and tractor hydraulics will run about 100 degrees above ambient temperature. So just feel one of your quick connects after running the tractor for about an hour. I'm sure you MMM is just fine, but you could always check the level to give you piece of mind.
What your sayings is true, i did check fuild level
and it seemed fine. i did check it hot and a small amount
squirted out do to pressure build up . thanks for your insight
   / 60 MMM DECK ON BX 22 (HOT) #4
You might try changing the gear oil to a synthetic and see if that improves it at all. At worst you've changed the fluid to one which has a higher temp threshold. I run Mobil 1 synthetic in my mower deck gearbox and the front axle on my B2400.
   / 60 MMM DECK ON BX 22 (HOT) #5
Just a word of caution, just in case, do not be feeling around under there with the machine running, that PTO shaft will hurt you badly. J
   / 60 MMM DECK ON BX 22 (HOT) #6
If it actually squirted due to pressure build up check the plug vent to make sure it is open.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
RIGID TOOLBOX (A52472)
2025 VOLVO VNL760 SLEEPER TRUCK (A54607)
2025 VOLVO VNL760...
