60 loader mounting brackets
/ 60 loader mounting brackets #1
JohnDeereHere
W-S,NC
1997 John Deere 670 4wd + 1987 John Deere 655 2wd+1984 John Deere 650 4wd
I recently purchased a used 60 loader for my 670.It came with no mounting brackets,but i thought "how expensive could 4 brackets really be?".I quickly found out.If i buy the brackets individually from deere i will spend $1000 dollars.Wow.The BM part number is no longer listed on deereparts.I have searched partsdepot.com but came up empty handed.Any ideas?Thanks!
AM107063 Left Front
AM107062 Right Front
AM107065 Left Rear
AM107064 Right Rear
/ 60 loader mounting brackets #2
Both the Model 60 and 70 are discontinued loaders. So, maybe that's why they aren't listed?
Well,here i am a year later.I finally have the loader brackets needed for the 60 loader/670 project.No instruction sheet was included.My dealer searched all of his resources,but to no avail.I contacted John Deere but came up empty handed as well.The loader owner's manual refers to an instruction sheet for the mounting brackets.But nobody seems to have it.It seems that all resources have been exhausted.Any ideas?Thanks everyone.
/ 60 loader mounting brackets #4
I have the Operators Manual for the 60, 70 and 70A Loaders, SN 110,001-
Manual number is OMM120877 L3 English
56 pages
Got it when I bought my 770 with 70 FEL 5 years ago, and the manual was new then. Seems like it might still be around. I'd copy it for you but I'd have to slice the binding off of it to do that. If you have no luck with that PN in a week or so, PM me and maybe I can work something out.
Dan,if you have time,would you see if your manual covers the installation of mounting brackets onto the tractor?I have the early manual,OMM79638,and it doesn't cover it.Perhaps a newer manual like yours would.Thanks again.
/ 60 loader mounting brackets #6
I have both your OMM79638 and a third version 60, 70, 70A loader manual, OMM115223. It also has no info on mounting brackets. Looks like the drawing and parts list on JD Parts should provide enough info to do the install. The operator manual does have info on adjusting the loader to the mounts.
/ 60 loader mounting brackets #7
Three pages with new install adjustment procedures.
/ 60 loader mounting brackets #8
Here is an instruction I found.
  • 60 loader.pdf
Excellent information.Just what i was looking for.I wonder why the publications department couldn't get ahold of it?You would think that a corporation as big as John Deere would archive this stuff.Oh well.Many thanks everyone.
/ 60 loader mounting brackets #10
Actually it is archived. That is where I found it. You just need to know where to look for it or be willing to put in the effort. Unfortunately you got someone who didn't try very hard or didn't know where to look.
/ 60 loader mounting brackets #11
Glad the other guys could help because that's much more detailed than what I have in my owner's manual. BTW, it looks exactly like the FEL mounts on my 770.
/ 60 loader mounting brackets #12
Probably are the same...there's a lot of similarity between the 670, 770 and 790.
