60" deck on X495
   / 60" deck on X495
Beenthere thanks so much for checking in to all this. That will help me out and possibly save me a few dollars. Have a good day!
   / 60" deck on X495 #12
You're welcome.
Since last post, I've decided the easiest would be to just have a new draft made up that is longer. Threaded on the ends, and bent to hold the front of the deck. Would only need to extend it in length by 2" (2 1/2 to be safe :) ) and using the X495 draft as a pattern.
Everything else would fit then and no changes need to be made to the deck or the tractor.
   / 60" deck on X495 #13
My dealer indicated to me the older style decks would NOT work when I asked. Are they jivin' me?? Sounds like you may be having success here.
John M
   / 60" deck on X495 #14
John True, not a perfect direct pin-on fit.
I hooked it up (the 54 deck under the x485) and the draft bail in the front is too short. About 2" is what it would take. But everything else lined up very well....lift arms and lift points on the deck, and the PTO. Can't think of anything else that would be needed other than the longer draft. Seems one could be fabricated out of 1" bar bent to the right "U" shape and threaded on the ends.
Deere dealers don't mess with anything that is not a direct fit. Trust me....I worked for one for several years after I retired. :) And they don't want to admit to something old being better than what they are selling new.
   / 60" deck on X495
Beenthere, I agree on what you said about older stuff being better. I too know salesmen that won't admit it either. Thanks for your help!
UNUSED FUTURE MINI EXCAVATOR COUPLER (A51244)
UNUSED FUTURE MINI...
John Deere 300 Tractor W/Loader (RUNS) (A50774)
John Deere 300...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2020 Case CX245D SR Excavator (RIDE AND DRIVE) (A50774)
2020 Case CX245D...
2014 Mack CXU613 T/A Day Cab Truck Tractor (A50323)
2014 Mack CXU613...
