60" compaired to 54" MMM
   / 60" compaired to 54" MMM #1
CFHartman
Keyser WV
John Deer 2210
60\" compaired to 54\" MMM
Could any one give me some pro and con of the 60" MMM compared to the 54" MMM beside's the 6" difference
Thank You cfh /forums/images/graemlins/confused.gif <font color="red"> </font>
   / 60" compaired to 54" MMM #2
Re: 60\" compaired to 54\" MMM
Do not know which tractor you are interested in, BUT, for a BX2200 the 60" MMM is a heaver steel gauge deck, you can also get closer to things since it sticks out a little more. I have no trimming to do when I cut my lawn, the 60 MMM does it all. Also you will get done a little sooner. I takes me 1.25 hours to cut 2 acres with a lot of trees and things to go around.
   / 60" compaired to 54" MMM #3
I was thinking that the 60 and 54 were made the same and it did not really change till you got down to the 48" deck (but I could be wrong)
   / 60" compaired to 54" MMM #4
</font><font color="blue" class="small">( Could any one give me some pro and con of the 60" MMM compared to the 54" MMM beside's the 6" difference
)</font>
The 60" has a self balancing linkage that is supposed to provide a better cut on rough terrain. It also sticks out further thus making it easier to trim close to objects without running them over with the tractor tires.
   / 60" compaired to 54" MMM #5
The big difference is that the 60 icnh deck makes trimming so much easier and it is more heavily built I believe. J
   / 60" compaired to 54" MMM #7
I'd imagine that the blade tip speed would be higher on the 60, than on the 54. The higher the blade tip speed, the better a mower will cut and discharge clippings. I had a 72" on my 3710. At 1000 rpm (mid), it sounded like a jet fighter. I only used it 2 times. It was such a PITA to mount and dismount, I just hung it in the barn and used a lawn tractor.
   / 60" compaired to 54" MMM #8
the smaller the cutting width the better the cut.
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
