6 year old tractor with 175 hrs, should 300 hour hydraulic fluid change be done now?
   / 6 year old tractor with 175 hrs, should 300 hour hydraulic fluid change be done now? #1
sweep
Ohio hill country
2006 TC45A
My 6 year old tc45a only has 175 hrs. Stored inside all year in temperature controlled environment. Should the "300 hour" hydraulic fluid be changed due to age and not hours-possible water/acid in oil build up or sludge be a concern?
Waste of money or needed?
   / 6 year old tractor with 175 hrs, should 300 hour hydraulic fluid change be done now? #2
6 year old hydraulic fluid? Better safe than sorry, yes change it. Cheap insurance.
   / 6 year old tractor with 175 hrs, should 300 hour hydraulic fluid change be done now? #3
I agree with John. And if you want to go the extra mile, try and get a sample about mid drain, and send it out for analysis. Should ease your conscience.
   / 6 year old tractor with 175 hrs, should 300 hour hydraulic fluid change be done now? #4
I'd leave the tractor sitting for a twenty four hour period and loosen the drain plug and see if you get any moisture!
In theory yes you should change it but the fact of not being in changing temps the chance of moisture is small and other wise the oil should be good!
   / 6 year old tractor with 175 hrs, should 300 hour hydraulic fluid change be done now? #5
Given that "real" tractors (whatever THOSE are) sit out for 30 years or more and don't ever get the hydraulic oil changed - - I would say changing it is very expensive insurance against an essentially zero risk.
Of course oil companies have conditioned us to believe that all sorts of bad things happen if oil changes are skipped, if a drop or two of moisture "contaminates" the oil, or even if the schedule is stretched a bit, but hey - they're SELLING OIL, right ?
BTW, I have "changed fluids" in my old junkers when in school and later those of my off-sprung - found water, sludge, etc and rear axle oils like molasses.
Other than "peace of mind" at the time it was probably a waste of money.
(in retrospect).
   / 6 year old tractor with 175 hrs, should 300 hour hydraulic fluid change be done now? #6
Change intervals are based on severity of use, hours and length of service, calculated by engineers for a particular type of fluid or a particular piece of equipment.
Every recomendation I've ever seen is based on the above, and/or....
'x' number of hours or 'x' length of time
Just because you don't use it don't mean the lubricant is like new because it has been absorbing moisture and holding contamination in suspension.....
In other words, change it.
I'm going to try this today to see if any water comes out but I'm probably going to change the fluid this week.
   / 6 year old tractor with 175 hrs, should 300 hour hydraulic fluid change be done now? #8
Change it so you have a benchmark
   / 6 year old tractor with 175 hrs, should 300 hour hydraulic fluid change be done now? #9
(in retrospect).
the day i changed the oil in my mustangs rear axle it was like u descriced so i but new in it the next day the rear end went out
   / 6 year old tractor with 175 hrs, should 300 hour hydraulic fluid change be done now? #10
That is what many/most of us have been led to believe.
The reality is that oil company sales droids come up with magic numbers designed to maximize their profits (-:
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
