6' tiller and 4035
   / 6' tiller and 4035 #1
RedFirstGen
Finger Lakes NY
Mahindra 4035
Yes? No? Maybe but pushing it? Going to pull the trigger and want to be sure. Thanks in advance.
   / 6' tiller and 4035 #2
I don't own one but want to and it would be a 6footer:D
   / 6' tiller and 4035 #3
At 30 to 33 pto hp, it would never run my 6' Howard in anything but gardens...
I've had it on a good strong 35 pto farm tractor and it would over load it if run for any length of time, tilling fields, especially in the summers heat...
I run it on my 45hp tractor...
SR
   / 6' tiller and 4035 #4
I think it would be asking a lot of the tractor unless the ground had been previously worked. In old sod or heavy sod I think it would be tough going.
Thanks all. I do have a 2 bottom plow and anything I till will be plowed first. I rented a 5' tiller this year and it handled it well with the plowed ground. But it did leave me thinking that the 5' just might be the max.
   / 6' tiller and 4035 #6
I run a 6 foot tiller on my 4025 (31 PTO HP) and it handles it well. That being said, I do not have rocks or heavy clay. I have tilled pasture and any small vegetation does not load it up. I do like the way that the 6 foot machine covers the tractor tracks.
   / 6' tiller and 4035 #7
The 4035 will handle a 6 foot tiller, and you will want the 6 foot to cover your tracks. I've tilled up to 4 acre food plots with mine on unbroken pasture. Only time its struggled was on wet ground, and that was due to the tractor tires loading up. Just understand you will be going slow.
Thanks all. Going slow is not a problem. It's not that big of a plot and any time spent on the tractor is happy time. :)
   / 6' tiller and 4035 #9
It will handle most 6 ft tillers fine. Rob's Howard tiller is most likely in another class, cost 3 times what most pay for a tiller.
   / 6' tiller and 4035 #10
It will handle it no problem
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2014 Ford Escape SUV (A50324)
2014 Ford Escape...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2015 GMC SIERRA 2500 SERVICE TRUCK (A52576)
2015 GMC SIERRA...
