6 port orientation
   / 6 port orientation #1
Tentman
Southland, New Zealand
Massey Ferguson 5445, IHI 25NX Mini Excavator
Hello Folks
I'm installing a 6 port diverter valve (Italian made - no name) on my Excavator. Its ports are labelled A1,A2, B1, B2 and C.
Normally and according to the flow diagram I have I'd connect the input flows to the "A" ports. However to mount the valve to the optimum orientation (solenoid down?) it would be better to use the "B" ports for input flow.
Does anyone know if this will create a problem?
Foster
   / 6 port orientation #2
On a 6 ported valve two of the ports are the "common" ports. These two are connected to supply and return lines of the main system. Connecting the valve differently will not provide the diverted function.
You will need to determine the flow path of your valve and plumb it accordingly
In the de-energized condition determine which ports are connected by blowing air through them. Then energize the coil and determine which ports are connected. This will determine how to plumb your valve.
Example de-energized
A1 connected to B1
A2 connected to B2
Energized
A1 connected to C1
A2 connected to C2
Above example A1 & A2 are the common ports
Thanks, I realize from your reply the answer to my question is No. When the valve energises it won't open the path from "B" ports to "C" ports.
Much appreciated.
NPK GH-7 Excavator Hammer (A50774)
NPK GH-7 Excavator...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Gehl 125 Grinder Mixer (A50774)
Gehl 125 Grinder...
2018 GMC Savana (A50120)
2018 GMC Savana...
2 Wheel Wagon / Cart (A50515)
2 Wheel Wagon /...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
