6 Lug to 8 Lug Wheel Adaptors
   / 6 Lug to 8 Lug Wheel Adaptors #11
I am not talking about a 5K series, I am talking about a 2002 John Deere 4210 compact tractor that is 28 HP with E-Hydro. The rear hubs are 6x6 bolt pattern which is a small skid steer hub. I want to put 15-19.5 tire and wheel on the back and I have found a set of 19.5 inch diameter wheels that have a 8 on 8 bold pattern. So I need an adaptor (not spacers) that bolts on to my 6x6 hub and converts it to an 8 on 8 bolt pattern. Does anyone know if that exists?
Thanks,
The 12.25x19.5 rims that a 15-19.5 tire takes come with 8x8" bolt patterns. If you wanted to fit one on a 2WD 4210, you would either need to have a custom wheel made with a 6x6" bolt pattern or have a machine shop make you one. The stock industrial tire size for a 4210 is 14-17.5 on a 10x17.5" rim, and as a 15-19.5 is larger, I would NOT put this on a MFWD tractor, lest you screw up your lead-lag ratio and wreck the front axle.
2826 (A58376)
2826 (A58376)
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
2394 (A58376)
2394 (A58376)
202480 (A54757)
202480 (A54757)
2017 Genie GTH-5519 (A53317)
2017 Genie...
TANK MANIFOLD (A58214)
