6 Lug to 8 Lug Wheel Adaptors
   / 6 Lug to 8 Lug Wheel Adaptors #1
JD3520Turbo
Mount Vernon, MO
2013 5083E, JD 4210 Compact
Does anyone know if you can buy 6 to 8 lug wheel Adaptors for a JD 4210. I am wanting to put 15-19.5 wheels on the back and I have found a set of wheels that are 8 lug, but my tractor is 6 lug. Are both of these bolt patterns the same as Skid Steer hubs?
Thanks for you help.
   / 6 Lug to 8 Lug Wheel Adaptors #2
Lenny out in Nevada at MotoSports Tech made me some 8lug rear steel spacers for my JD 5k series .
I’m sure he could custom make you a set.
   / 6 Lug to 8 Lug Wheel Adaptors #3
8 lug rear on JD 5k series have a 8” bolt circle I’m pretty sure.
20mm diameter bolts
   / 6 Lug to 8 Lug Wheel Adaptors #4
20mm diameter bolts
I can confirm that the 5K series has an 8 on 8-in bolt circle. However, early models came with 16 mm lugs and later models came with 20 mm. I believe it was somewhere around 2003 plus or minus a year when they switched over during the 5x20 series. Also some models came with a reinforcing ring around all of the lugs and some didn't.
I am not talking about a 5K series, I am talking about a 2002 John Deere 4210 compact tractor that is 28 HP with E-Hydro. The rear hubs are 6x6 bolt pattern which is a small skid steer hub. I want to put 15-19.5 tire and wheel on the back and I have found a set of 19.5 inch diameter wheels that have a 8 on 8 bold pattern. So I need an adaptor (not spacers) that bolts on to my 6x6 hub and converts it to an 8 on 8 bolt pattern. Does anyone know if that exists?
Thanks,
   / 6 Lug to 8 Lug Wheel Adaptors #6
Maybe have a machine shop turn out a couple plates with the two bolt patterns for that adaptor. Seems to a certain extent, they will be spacers.
   / 6 Lug to 8 Lug Wheel Adaptors #8
Thanks,
We were saying 8on8” BC is what comes on a 5k series rear.
Adaptors will have to be at least a 2” thick spacers so they’ll have threaded holes deep enough to accept 16mm or 20mm bolts holding on the 8 lug wheels.
You’ll have to have them custom made.
Call Lenny at motosports tech I mentioned.
You can’t buy them off the shelf
   / 6 Lug to 8 Lug Wheel Adaptors #9
@JD3520Turbo did you call motosports tech about some adaptors ?
   / 6 Lug to 8 Lug Wheel Adaptors #10
If you have a set of 6 lug wheels to cut up, a good welding/fab shop could cut the 8 lug centers out of the wheels you want to use and weld in the 6 lug centers you need to match the tractor. No adapter needed, no spacer making wheel track wider. Naturally youd want the wheels to run true, but it's not a big deal on a tractor if it's out a bit. I've got the tools and skills, I'd do it for you if you are close.
CABINET OF HOSE ENDS (A58216)
CABINET OF HOSE...
4 SEMI MOTOR SHIPPING BLOCKS (A58216)
4 SEMI MOTOR...
7ft Workbench (A57454)
CFG Industry MX15RX Mini Excavator (A57149)
CFG Industry...
2009 Ford F-150 Crew Cab Pickup Truck (A56858)
2009 Ford F-150...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
