6-in-1 bucket (multi-purpose bucket)
   / 6-in-1 bucket (multi-purpose bucket) #1
VAN1965
Toolcat 5600
Has anyone try a 6-in-1 bucket (bucket, dozer blade, grapple, etc..) on their toolcat - how useful are they? Or are you better off buying individual implements?
   / 6-in-1 bucket (multi-purpose bucket) #2
Bought one with my Toolcat about 4 years ago. Couldn't do without it. Have done about everything with it that you could imagine it doing (carrying loads, clearing brush, moving fallen trees, grading, maintaining a long dirt driveway, digging, etc., etc,) and it has never let me down. Along with a mower and forks, I've been able to do everything I need to do on our 40 acres. Excellent implement. Excellent investment.
   / 6-in-1 bucket (multi-purpose bucket) #3
i bought one although it was called a 4 in 1. will grapple, doze, backcut and i think is the same thing you are talking about. I love it and would recommend it highly over a regular bucket. It is very useful.
   / 6-in-1 bucket (multi-purpose bucket) #6
The correct answer is - "It depends". I have a 4in1 on my compact wheel loader but also have grapple bucket and tooth buckets. Also have a TC with lots of attachments.
Dozer blades on smaller machines, work well with loose material or fairly limited grading. It takes weight, traction and stable wheel base to handle a dozer blade well. The TC does not have those qualities. A true dozer does. My 13K lb wheel loader is not great. A large frame, tracked skid steer will do better but still can be difficult to manage with a dozer blade. Most guys can grade better with a bucket on a skid steer rather than using a dozer blade. Much easier to use a box blade with scarifers compared to a dozer blade on a TC for grading or loosening material.
The grapple of a 4in1 cannot carry near the material of a true grapple. It just does not have the grabbing capacity and can't hold on to material as well.
The extra weight of a 4in1 grapple also can have significant negative effect on lifting capacity.
If you have limited use for a grapple, or dozer blade, and don't mind the decrease in lifting capacity, then a 4in1 can be very handy. I would be careful with a dozer blade on a TC. Digging with just the corner of a dozer blade could be a little hard on the central boom of the TC.
The only reason I have a 4in1 was because I found it cheap. It is over 2000 lbs, 100" wide and was never used but was several years old. Paid $1500 for it.
   / 6-in-1 bucket (multi-purpose bucket) #7
The multipurpose bucket is a huge time saver; the best and most cost effective attachment for my toolcat that I've ever bought.
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
F550 CM Trucks 11ft Utility Bed (A49461)
F550 CM Trucks...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
71059 (A49346)
71059 (A49346)
2009 International Frazer Bilt X-514 Ambulance (A49461)
2009 International...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
