TractorGuy
Elite Member
- Joined
- Sep 15, 2013
- Messages
- 4,616
- Location
- N. FL
- Tractor
- John Deere 4310 CUT, Ford New Holland 575E Cab Backhoe (sold), John Deere F725 Front Mount Mower, Kubota LX3310 cab.
I will preface this post by saying I saw no real difference in mowing quality afterwards. To make a clean one pass cut in Pensacola Bahia you need a faster blade tip speed than you get with most finish mowers. There may not be a mower that can achieve a clean one pass cut in Bahia.
The Agmate 6' finish mower has an advertised blade rpm of 2223 but my calculations with their advertised gear ratio works out to 2180. This is a blade tip speed of 13,690 feet per minute. I did a little checking and found out their 4' mower used the same gearbox, spindles, and belt pitch but has a larger gearbox pulley. The 5'&6' mowers have a 7.864" pulley while the 4' mower has an 8.5" pulley. Not a huge difference but I figured any increase in blade speed might improve the cut quality. I was able to install the 8.5" pulley and use my same belts. I had to get the belts in the pulley grooves with the gearbox mount loose but after getting all the bolts in and tight I still had to use the tensioner to tighten them a little. I won't go into all the math but it increases the blade tip speed from 13,690 FPM to 14,820 FPM.
I noticed while it was sitting on a level surface with an equal number if spacers on each wheel the deck was a half bubble higher in the front so I took out a 1/2" spacer from the front wheels to get it dead level. I also installed new blades. Also the pulleys are slightly different in construction. I measured the belt groove distance from the gearbox mount and found I had to remove the two washers that were installed under my existing pulley to get the same belt alignment.
When mowing the thicker areas I did hear some change in engine sound which I rarley heard before so it is laboring the tractor a little more. My little tractor only has 19 PTO HP so I think I found the limit on it with a modified 6' finish mower. The tach remained steady so I'm not concerned about it.
Finally if anyone wants to do this the part number for the 4' mower pulley is 69620. Don't forget to measure distance on your existing pulley but I suspect you will need to remove the two washers from underneath as I did.
