Leejohn
Elite Member
If you are changing at the 100hr mark what is being gained for double the money?
Recently in my V8 truck in non-severe service I went almost 10,000 mile on synthetic oil with a quality filter. I used to change with less mileage than this but a lot of guys that test their oil say it can go even longer than 10,000 miles. In tractors that get severe usage I change once a year and in those with lighter usage maybe 18 months. I don't usually hit the 100 hours between changes.
I change a tractor to synthetic at 100 hours or so and vehicles at maybe a few thousand miles. I think even this is changing because I have owned two vehicles that came from the factory with full synthetic.
Your logic is flawed as are many others.
5w30 is NOT thinner than 10w30
5w40 is NOT thinner than 15w40
They are the SAME.
Last number (after the w) is the oil thickness. The first number tells you how much it thickens when cold. That is why you don't notice any additional leakage in the old tractors. Because you are running the SAME weight oil in there. Just a little better performing as it don't thicken up "as much" when cold as 15w40 does.
The primary reason for auto manufacturers to have moved to 0 weight is for engine efficiency. Just about every manufacturer is striving for that. Less friction means more gas mileage. I have an all wheel drive Forester that regularly gets 35 mpg. It uses 0-20 synthetic. Shear concerns have more to do with dino oil than synthetic which remains pretty stable..
I have not found any appreciable need for something like a 0wXX oil. I don't live in the interior of Alaska anymore. A 5wXX or 10wXX serves my needs quite well. The problem that can occur when the spreads between the cold flow rating and the weight of the oil increases, the amount of viscosity improvers also is needed. it is those VI's that tend to shear under pressure and the motor oil breaks down. a 10w30, for instance, is more shear stable generally than a 15w40. And especially more so than a 5w30 or 5w40. And the issue I have with a 0wXX oil is that the cold flow to viscosity ratio is so extreme, that shearing is something to seriously consider. There are different quality VI's that can negate, somewhat, the dramatic effect of shearing, but cannot eliminate it. Each individual application is different. Chevron recently brought out a 15w30 HDEO that is extremely shear stable. They are pushing it for local P&D type trucking operations primarily.
The issue is not quite as you stated. What is the viscosity of a 0w20 weight oil... 8.5 - 8.7 cSt at 100C. What is the viscosity of a 5w20...8.5 to 8.7 cSt at 100C. It doesn't matter. At operating temperature, the viscosity is the same. As I have contended, the 0 or the 5 in front of the "w" is winter flow rating only. Nothing to do with viscosity. There is no 0 weight oil, synthetic or not, on the consumer retail market. There is a 0 winter flow rating, in the form of 0w20, 0w30, 0w40, but not a 0 weight.
There is an argument to be made that a 20w oil is more fuel efficient than a 30w oil, and that would be the reasoning for auto OEM's specifying a 20w as opposed to a 30w oil, but the winter flow rating has virtually no effect in that regard.
Wolfy may not believe that a 5w30 and a 10w30 are not the same at operating temperature, but that doesn't mean that they aren't. All of these oils have virtually the same viscosity at operating temperature. I selected different brands to prove the point in fairness....
A modern synthetic 5w30 has a viscosity of roughly 10.4 cSt at 100C (Amsoil)
A modern synthetic 10w30 has a viscosity of roughly 10.2 cSt at 100C (Mobil 1)
A modern conventional 10w30 has a viscosity of roughly 10.5 cSt at 100C (Pennzoil)
As I have stated, a oil of a particular weight have the same viscosity. How they flow when cold in the winter is another issue and the number in front of the "w" is that rating.
There is a case that a synthetic has better overall properties, for sure. But it still has the same viscosity in the same grade as a conventional. How an oil has the viscosity it does and and the winter flow rating it does is primarily dependent on additional viscosity modifiers that are present in the oil. Some, like synthetics, require very little VI to reach the goal. Conventional's generally need more VI to have a low cold flow rating. There is a limit to how much VI you can use in an oil to achieve this. This is why you cannot buy a conventional 0w30 for instance. It is not practical to make one. It requires a synthetic or at a minimum a synthetic blend.
