5w or 10w question
   / 5w or 10w question #1
humbledeere
S.E Wi.
JDX500
Hi,
Thinking of staying with 10w30 for winter snowblowing (X500) as the machine is kept in heated garage (never colder than about 42degrees)
   / 5w or 10w question #2
Welcome to the forum. I wouldn't worry a bit about it... you're storing it in the 10W-30 temperature range, then the oil's not cooling while you're working it until you put it back at 42...
thanks - i am just a nervous nellie. never had a real machine b4 and don't want to mess her up.
   / 5w or 10w question #4
If worried, then change oil to Mobil 1 10w-30. Flows better than a 5w at low temps, and protection of a fully synthetic at operating temps. Synthetics provide the resistance to shear forces at the connecting rod bearing 3-4 times greater than a conventional oil. few quarts, cheap insurance. :cool:
   / 5w or 10w question #5
Why not use a 5w30 or 0w30 year round? The 0w30 Mobil 1 is what I use. It's okay for light duty (e.g. don't go for 200 hour drains) diesel use. I even used it in my 1983 Benz diesel. It gave 1 mpg increase over 5w40.
Even a 0wxx will be heavier at startup than the "xx" value at operating temperature, even startups in the hot summer.
Ralph
Case Axial-Flow Combine Wheels NO RESERVE (A55301)
Case Axial-Flow...
KUBOTA M7-132 (A53084)
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
PENDING SELLER CONFIRMATIONS (A54607)
PENDING SELLER...
2019 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2019 Top Hat...
