5w or 10w question
   / 5w or 10w question #1
humbledeere
S.E Wi.
JDX500
Hi,
Thinking of staying with 10w30 for winter snowblowing (X500) as the machine is kept in heated garage (never colder than about 42degrees)
   / 5w or 10w question #2
Welcome to the forum. I wouldn't worry a bit about it... you're storing it in the 10W-30 temperature range, then the oil's not cooling while you're working it until you put it back at 42...
thanks - i am just a nervous nellie. never had a real machine b4 and don't want to mess her up.
   / 5w or 10w question #4
If worried, then change oil to Mobil 1 10w-30. Flows better than a 5w at low temps, and protection of a fully synthetic at operating temps. Synthetics provide the resistance to shear forces at the connecting rod bearing 3-4 times greater than a conventional oil. few quarts, cheap insurance. :cool:
   / 5w or 10w question #5
Why not use a 5w30 or 0w30 year round? The 0w30 Mobil 1 is what I use. It's okay for light duty (e.g. don't go for 200 hour drains) diesel use. I even used it in my 1983 Benz diesel. It gave 1 mpg increase over 5w40.
Even a 0wxx will be heavier at startup than the "xx" value at operating temperature, even startups in the hot summer.
Ralph
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2017 CATERPILLAR...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
16FT Flatbed Truck Body (A52377)
16FT Flatbed Truck...
