Fallon
Super Member
Looking to hear people's experience about towing a bumper pull with a side by side on a rack over the bed/cab or pulling a medium/small 5th wheel with a double trailer (2,000lbs of side by side). Not teribly tractor related, but hoping the TBN hive mind has some experience on this front.
We mostly dry camp. No campground or hookups. Just head out to the woods for a long weekend. We don't want to take the camper offroading, but some of the dirt roads aren't great. We are planning on some longer multi-week trips to national parks & what not that would likely be normal campgrounds as well. Just me, the wife, the 45lbs dog & in some cases the cat. We have a 2 seater Artic Cat SxS toy that weighs around 1,400lbs.
2014 F350 double cab short bed (6.5') & PowerStroke. Weighs around 9,400lbs with toolbox & normal gear load for traveling, camping, etc. Thinking about pulling the bed & putting an aluminum flatbed on in many scenarios so I can toss a tractor implement on. I need a skirted one with built in toolboxes under the deck to replace the bed box I have now that would block a ramp or 5th wheel hitch..
Former option: 17' Casita, 3,500lbs. Towed well with my former Toyota Tacoma. I could have towed it without wheels on at freeway speeds well with the F350. It was too small for us to live in & a F350 powerstroke not being appropriate for keeping up on trails with friends lead to getting the SxS.
22' flat deck trailer (4klbs) & 8klbs of tractor & implements, 12klbs total (Same as the Carbon 35). 1,000-1500lbs tongue weight according to the WeighSafe hitch, no WDH or sway control. Load varies depending if it's my tractor or somebody else's or how many implements. Tows down the highway at 75 & have it 80 (usually keep it under 70 though) with no issues as long as I balanced it right with the WeighSafe hitch. Feels solid & well behaved. Irrelevant for camping, although I could in theory haul the SxS on it. Baseline for what the truck can tow well that I keep comparing the campers to that weight equal or less. F350 needed to haul this setup for my side job doing tractor work.
Current setup:
35' Carbon 35 bumper pull. 12klbs loaded, 1,500lbs tongue weight (with toy in the back, excessive tongue weight without), Blue Ox WDH & sway control. All axle, hitch , GVWR & other weights in spec as per Cat scales. Very twitchy over 65mph & not super pleasant to tow. I'm wiped out after 4-5 hours of towing so really won't take it out of Colorado, or even longer in-state trips. As we've found out, it's generally too big for our uses, even if it towed well. Its length means any little hill get uncomfortably close to the plumbing hanging low in the middle. Difficult to maneuver even with lots of room & won't fit in may campsites or off-grid locations.
Pro:
SxS bed rack
Replace 35' toy hauler with 25' bumper pull trailer around 6-7klbs
Has anybody hauled a setup like this? Looking to get the SxS camping & get a camper that is nicer to tow. Does the balance with a 2 seater SxS on a bed rack & "half ton towable" type trailer work out for a 1 ton SRW truck? I can definitely crunch the numbers, but there are a lot more unknowns with this setup than I can easily calculate compared to normal trailer weights (even considering most dealer weights are lies).
I think I will be close on the rear axle ratings with about 2,000lbs of side by side & ramp plus 5-700lbs or tongue weight. But a WDH will help shift some of the weight up front.
Basically a setup like.
Pro:
25-26' 5th wheel non-toy hauler with a decent frame & a small aluminum trailer for the toy & pull doubles. Doubles are legal in Colorado & we probably won't be looking at hauling the toy out of state.
Pro:
Options we have considered but probably don't meet our needs.
24-26' bumper pull toy hauler
Pro:
Gooseneck horse trailer based toy hauler
Pros:
5th wheel toy hauler
Pros:
Con:
Con:
Current setup:
Pro:
- Hauls toy
- Big enough to live in for longer trips
- 2 slides make it nice & roomy in kitchen/living area
- Sleeps 7+ (only 2 of us + 1-2 pets though)
- Unpleasant to tow above 65 & can be a bit twitch at 65
- Unpleasant to maneuver due to excessive length, impossible to fit in many places
- We never use the 12' of garage other than for the toy (queen bunk beds there are useless), very occasionally for guests
- Length makes dirt roads & uneven stuff problematic for the plumbing
- Max rated tongue weight for the truck if the toy is loaded & WDH is on (otherwise it exceeds tongue weight ratings
SxS bed rack
Pro:
- Towing a reasonable length "1/2 ton towable" trailer with a 1 ton will be a breeze
- Can easily load up the toy on the truck if I can't drive it to a trailhead in camp
- Could fit a 4 seater SxS on the ramp of we upgraded from our 2
- Some effort required to load the toy on a steep ramp
- May be a bit heavy combining toy weight & hitch weight
Pro:
- Tows well & no sway issues (without the double for sure)
- Can detach the toy & trailer for extra maneuverability if needed
- Towing doubles can be complex & long
- Towing double outside of Colorado will be limited
Pro:
- Lighter & should be easier to haul than the 35' Carbon
- Less length for maneuverability & dragging plumbing over bumps
- Possible gas/exhaust fume issues that sometimes give the wife migraines (probably a deal killer, but well have to see)
- Possible balance issues towing empty
Pros:
- 5th wheel/gooseneck doesn't sway
- Not that tall
- Aluminum frame is likely to last better
- Low ride height will leave use with dragging issues on dirt roads
- Expensive
- Interior finish quality is as cheap as every other RV
- Low roof in master bed area (not horrible, but inconvenient)
Pros:
- Tows well
- Typically huge (tall, long & heavy)
- Less maneuverable than the current Carbon due to length
- May run into issues with not being able to isolate fumes if we find a smaller one
- Probable balance issues without hauling the toy
Con:
- Another engine to maintain
- Expensive to buy another engine
- Probably weaker than the F350 powerstroke
- Possible ground clearance issues
- Need a lifeboat to get away from campsite & toy isn't road legal
Con:
- Smaller than our 17' Casita at best & that was to small
