5th wheel hitch for 3 point.
   / 5th wheel hitch for 3 point.
Since it looks like a gooseneck in your picture, can you post a picture of the hitch that is on the trailer?
It has a 5th wheel adaptor in it. Its not gooseneck ball.
   / 5th wheel hitch for 3 point. #12
OK, thanks.
   / 5th wheel hitch for 3 point. #13
You can get a hitch for you 3pt that will carry a gooseneck. If you don't need to swap back and forth from truck and tractor usage regularly you could purchase the adapter as you pictured except for gooseneck that you could swap out as needed. OR you can purchase a 5th wheel to gooseneck adapter which would still take some time to swap when needed.
   / 5th wheel hitch for 3 point. #15
Something not mentioned is your safety. The hitch will be significantly above the tractor axle. This can make the tractor rear up, rotating around the rear wheels. Front weights /FEL will help but rearing is still a potential. The trailer hitting a hole or curb can suddenly cause the tractor rearing.
I use the 3 point to move a GN trailer, but rearing is always in my mind to avoid and be ready to counter.
   / 5th wheel hitch for 3 point. #16
I dont know anything about fifth wheel, but my brief google searches on this topic make me think you should really try and go get that $75 piece and make something out of it. I don't see a turn key solution to this (an adapter) that doesn't cost at least $500.
   / 5th wheel hitch for 3 point. #17
I had 27 foot goose neck with a 2 5/16 ball. I had a ball welded to the top of the post of a 3 point hay bale spike. I was able to pull the trailer with my cab TL80A. The only problem was the trailer had a deck over the neck so it limited how sharp I could turn. Used it in parades and as a hay ride for several occasions. 40-50 people with no problems. I would wrap x-mas lights around the trailer on the railings and with no brakes. I covered the spike with a piece of PVC to keep from stabbing someone, it also keep people from walking between the tractor and the trailer.
I see no reason the 5th wheel hitch would not work as well.
Exactly the same deal with me and I've pulled my tandem axle Kauffman well overloaded with round bales, from the field to the barn via dirt roads. Welded the ball on the top post of my 3 point hay spear.
N0 brakes needed, not going that fast to need brakes and I do have to be careful about turns too as mine is also a deck over and will do bad things to the back of the tractor cab if I'm not watching.
I like doing that because I don't have to wind up the landing gear. Just leave it extended and lift the trailer a bit. Hauled enough rounds to make the trailer 'smile' a bit. I do stick my magnetic LED flashers on the back end of the trailer anyway. Been doing that for years now.
   / 5th wheel hitch for 3 point. #18
I've stacked over 30K in rounds on the trailer in the past and the tractor has never felt front end light at all. Don't put any on the deck over, just in the well. The trailer will smile a bit however.
   / 5th wheel hitch for 3 point. #19
Whether a gooseneck or a 5th wheel hitch setup, the pin weight needs to be kept in mind. Try to apply the weight as close to the tractor as other considerations will allow. Be really mindful of how the trailer is loaded. (Clearly the pin weight on the trailer in the photo of the truck/trailer/tractor is too high.) Pin wieghts in the 20-25% of the trailer gross for highway use is not uncommon. However, with the low speed of a tractor, you could reduce that percentage significantly.
Go easy on the 3ph...they can get pricey to repair if it slams up and down.
Weigh-Safe has recently come out with some hitch/scale combinations that may help. Other manufactures also have similar products.
UNUSED AGT INDUSTRIAL SDA-140W LOADER (A51243)
UNUSED AGT...
Wolverine Quick Attach 72" Bucket (A50514)
Wolverine Quick...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52128)
2023 New Holland...
