5th wheel hitch for 3 point.
   / 5th wheel hitch for 3 point. #1
xring100
Livingston County, Michigan
Kubota M8540, ZD1211 60"
I know i haven't posted much lately. I've some pretty serious health problems that I'm still trying to recover from.
I got really tired of having to pull my 2wd international and camper with the tractor every time the grass was wet. I have since brought in 40 yards of crushed concrete and put it down by the road but i park my camper about 400-500 feet off the road and probably use about 900 foot loop which is entirely separate from my normal drive so stone or concrete is prohibitively expensive.
I bought the upper half of a 5th wheel hitch. Not concerned that its only rated for 16000lbs as it will never be used over about 4 mph.
I Bought some steel c-channel and dusted off the hypertherm 45xp plasma cutter to shape the steel to fit around my quick hitch. I then welded it up with my miller 252. I have to use this every spring as its a very slight uphill climb to the parking spot.
If i know its bad i just unhook at the road and grab the tractor.
The empty pin weight is about 3700lbs on the camper
I can't turn as sharp as with the truck but I'm able to extend the top link a long ways and push the camper rearward if i really need to turn 20180610_150950.jpeg20180402_163258.jpeg20180603_142330.jpeg20180603_144504.jpeg20180603_161651.jpeg
Newman Tractor 12in Excavator Digging Tooth Bucket (A55787)
Newman Tractor...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A51406)
(INOP) 2016...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
378813 (A51573)
378813 (A51573)
2003 Komatsu WA250-3MC Articulated Wheel Loader (A55787)
2003 Komatsu...
