5T Cross Country Trailer- What's it worth?
   / 5T Cross Country Trailer- What's it worth? #1
GalwayBoy
Saratoga County, NY
JD 4120
Hi group,
I'm looking at an equipment trailer, and could use some help putting a value on it.
Here's the specs- 1992 Cross Country 4HD16, 9700# CGVW, two axle, drum brakes on one axle only. Pintle hitch. Deck is seven foot wide, with a total lenght of eighteen feet. I think they must spec it as a sixteen based on the stored position of the ramps. Although the unit could use a paint job, it's in relatively good physical shape.
What it needs- Full set of lights and a battery kit for the brakes, A minor repair of the tongue jack. Could use a tire replaced due to several sidewall cracks.
Now the odd part- Tires are clearly not original with the size being 7x14.5 LRE (10 ply)
The tires are rated at around 1800 lbs @ 70 PSI max inflation, meaning we've got a 5 ton rig with 3.5 ton tires. Tires should have been 14 ply (LRG max load 3k+)
I've got a Deere 4120 with a 448 hoe, which would pretty much max out the present rubber. I can forget about loading on anything else.
Suggestions?
Thanks,
Jon
   / 5T Cross Country Trailer- What's it worth? #2
In Dec, '03 for $2560 I bought a 4HD16. GVWR 9750# Load 8000#. Tires front + rear 7-14.5LT tubeless Load Range F DOT7FMK S 2300 D 2020. Inflation 100 psi.
I measured the bed @ 16'x78". Electric brakes both axles. Re-charging break-a-way kit by Buffalo Switchworks Model 96927 phone 800-862-4032. 2" hemlock planks show no rot. Cross Country Mfg.' Inc. is in Greene, NY , (maybe not too far) phone 607-656-4103.
I was told by the dealer in CT that anything bigger such as 5HD16 requires a Class II License so I bought 4HD. I have around 6000# of tractor + equip. so I'm ok so far.
Anyone know what the S stands for in S 2300, the D, the 7FMK, the LT in 14.5LTor the 12PR on the tires?
What's a good trailer tire with higher load capacity?
   / 5T Cross Country Trailer- What's it worth? #3
The s is for single tire rating and corresponds with the D which is when used in a Dual Tire configuration
The LT stands for light Truck
I believe that actually an D rated trailer tire (ST for special trailer I believe) actually has more load capacity then an E LT tire.
   / 5T Cross Country Trailer- What's it worth? #4
LT might mean light trailer in this case.
12PR is 12 ply rating of the tire.
Load range F is the weight rating of the tire. The higher the letter the more weight it can handle.
Looks like someone replaced the tires on the trailer Jon is looking at with a lower weight rated tire.
Since the 1992 trailer needs new lights, paint, a battery kit, tongue jack repair or replacement, and it needs a new set of the proper tires to bring it back up to the weight rating (about $650-850) and it's over 14 years old may need new brakes as well. If I was going to sink about a grand in parts into this used trailer I'd put the price between $1000-1300 max.
That's my opinion which along with $1.00 will get you a coffee in most places.
Thanks, guys.
I figuerd to spend in the area of $600 to bring it up to snuff, not including the paint. (The tractor doesn't care about the trailers' paint but *I* do...)
I don't know the price of a new 4HD 16, but I figure that I could purchase something comparable in a lesser brand for <$2.5k. Keeping in mind that I see intact used trailers selling in the $1000-$1500 range , I offered $500 for it. Needless to say, i haven't heard back from the owner yet. Hey, I can always offer more...
It's been sitting, and overgrown with weeds. It can surely sit and be covered in snow.
FWIW- Concerning the tires. Seems like LRG might be overkill, but a 8-14.5 LRF could also work well. I think the extra plies cost more than the added width.
I tend to prefer a little margin of safety though in matters like this rather than push it to the limit.
I'll let you all know if there's a happy ending.
Jon
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
2006 HEIL MC407 (A52472)
2006 HEIL MC407...
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A52472)
100 GAL FUEL TANK...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
