Mowing 5ft. rotary mower
/ 5ft. rotary mower #1
rccoyote
Cooke County, Texas
Yanmar 1820D
I was wandering if someone could help me out. I just purchased a 5ft. brush hog made by Servis Equipment, Dallas TX.(what it says on the serial# plate). It is the "Chico" model.
Is this a light duty, medium??? Also was wandering about the proper method for adjustment. As I've got it hooked up,(1820D) I can only get it to mow at about 2 or 3 inches. I've got to be doing something wrong. I think these things should be able to mow at a much higher height. I am using a solid adjustable top link from tractor supply. The wheel beem seems to be set at its lowest bolt hole(highest mowing) adjustment. Not sure what the age on this pup is but it's several years old. Has some rust holes that have been patched with plates welded to the top deck. I know Buck at EFC does not reccomend a 5ft. brush hog behind an 1820D (asked in an earlier post) but the price was rite. $200. I was also wandering about backing up with the PTO engaged. Is this O.K. to do?I apologise for the newbie questions, but this is my first brush hog. I actually got it hooked up and mowed about 2 acres of 1ft. to 1&1/2ft. tall grass. It was excedeingly slow because i was cutting at the aformentioned 2 inch height adjustment, but it seemed to cut really well, and engine rpm never droped below 2000, except 2 or three times in some really thick wet stuff. I think my mowing progress would speed up if I could get some help on figuring out how to adjust for a taller cut. Thanks rccoyote
/ 5ft. rotary mower
Thanks for the link Bird. That was some interesting reading. I had no idea I had purchased a Rhino brush hog! Makes the $200 dollars i gave for it seem really well spent! I tried attaching a pic i took with the digital cam but TBN kept telling me that my post could only be 10000 or something. Not exactly sure how to reduce the size of the jpeg. I'll work on it though. rccoyote
/ 5ft. rotary mower #4
Are you lifting the front of the cutter to level or higher with the 3ph and locking it in with the stop bolt?
/ 5ft. rotary mower
Yep...got it level and got the stop bolt set. It's at about 2 inches. I was reading thru all the back posts just befor I bought it and someone says that a slight rise in the front puts less strain on the pto. Not sure if thats true or not but even with the hydraulics raised any more than they are now I start lifting the rear wheel off the ground. I have the connecting links in the last hole on the lower arms. Is that the correct hole? Or should I be using the hole in the arm closer to the tractor?(usually where I put it for the tiller) rccoyote
/ 5ft. rotary mower
Here is an attempt at a pic of my setup.
/ 5ft. rotary mower
Another angle. (Thank goodness for MGI)
/ 5ft. rotary mower #8
Good pictures. If you want to raise the front end of the mower to cut higher without picking up the back wheel, you need to adjust your top link (lengthen it). Now if you had as good a picture of the back end, we could see why it isn't set high enough to suit you. You undoubtedly know that adjusting the height at the rear wheel can seem just a little backward; i.e., with the mower lifted, you lower the rear wheel so when you let it down to the ground it holds the mower higher.
/ 5ft. rotary mower #9
It looks like the verticals on your lift arms are set too far to the rear. The lower lift arms should have 2 holes on each arm that the verticals can be pinned to. Move the verticals to the holes closer to the tractor. That should give you more lift.
/ 5ft. rotary mower #10
Bird's got it right. Your top link is adjusted to its shortest position. You need to lengthen it to allow the front of the mower to go higher before taking up the slack in that chain that eventually lifts the rear of the mower.
Keep in mind that you want to try to keep the rear of the mower a little higher than the front when mowing. If the rear is lower, then you cut the grass twice - once at the front of the mower, and then again at the rear, because the grass is still tall enough to encounter the blades at the back of the mower.
/ 5ft. rotary mower #11
Looks like to me that the pins on the mower that your lift arms are pretty high. That will limit how high you can lift the mower. One solution is to drill another set of holes closer to the deck and moving the pins down. Also I have a set of check chains which go from the top link pin on the tractor to the pins on the mower. This lets me run the mower much higher and get instantly back to that level if I have to lift the deck for an obstruction. When you are mowing high the tail wheel isn't touching the ground.
Chris
/ 5ft. rotary mower #12
"The wheel beem seems to be set at its lowest bolt hole(highest mowing) adjustment."
There's something wrong there. Try it the other direction, I can't believe it can be adjusted to cut any lower than 2-3". Also you need to lengthen the top link to allow you to raise the front and keep the rear wheel on the ground.
/ 5ft. rotary mower #13
</font><font color="blue" class="small">( Looks like to me that the pins on the mower that your lift arms are pretty high. That will limit how high you can lift the mower. One solution is to drill another set of holes closer to the deck and moving the pins down.)</font>
I think that peenwalk hit it. A lot of compact tractors need the lower pins moved down on the implement. For some reason, the manufactures set the pins at the height for a utility tractor even if the implement is small enough for a compact.
/ 5ft. rotary mower
The top link extension worked!.I put my longer top link on it and extended it a bit till the length of chain on the cutter had some slack in it. Amazing. Let me raise the durn thing a good 10 inches before the rear wheel starts to come off the ground!
For some crazy reason I was thinking that little length of chain had to be taught. Not so! Thanks a bunch Bird, and all the rest of ya'll that responded. Congrats on your moderatorship Bird! Thanks again. rccoyote
/ 5ft. rotary mower #15
</font><font color="blue" class="small">( I was thinking that little length of chain had to be taught. Not so! )</font>
Well, don't feel bad. My first brush hog had a chain there and I tried it with the chain taut, too. /forums/images/graemlins/frown.gif It didn't take too long to figure out that it worked better with a little slack in the chain. Glad you got it adjusted to suit you. And that's a pretty tough looking brush hog, too. I think you may have gotten a really good deal on it.
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
UNUSED KUBOTA TRACTOR SEAT (A64280)
UNUSED KUBOTA...
Street Sweeper (A60352)
Street Sweeper...
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A61574)
2017 Forest River...
2025 60in Bucket Skid Steer Attachment (A61572)
2025 60in Bucket...
(1) UNUSED 8.3-24 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 8.3-24...
