59 Ford 631 Spring at bottom of throttle lever...
   / 59 Ford 631 Spring at bottom of throttle lever... #1
dos0711
Northeast,Florida
1959 Ford Workmaster 631
What is the purpose of the spring, washers and cotter pin that I've circled in red? Mine are missing and wonder if I should replace them.
   / 59 Ford 631 Spring at bottom of throttle lever... #2
It probably just keeps the linkage from "pivoting/flopping" around and much and keeps everything more snug with less play. Does the engine rpm seem pretty constant/governor work well?
Yes the governor works fine. The comp spring is in place and it holds a speed.
   / 59 Ford 631 Spring at bottom of throttle lever... #4
Maybe it reduces wear over the long term. I'd say that your machine has held up pretty well as is :)
Soundguy what are your thoughts...?
   / 59 Ford 631 Spring at bottom of throttle lever... #6
I always assumed that it was intended to keep the throttle shaft from riding up out of position. The spring would allow some axial movement which would prevent binding, as opposed to a cotter pin and washer.
   / 59 Ford 631 Spring at bottom of throttle lever... #7
agreed.. it's securing it in place and keeping it where it should be.
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
HEADACHE RACK (A50854)
2012 PETERBILT 388 NATIONAL CRANE TRUCK (A50854)
2012 PETERBILT 388...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A50860)
2012 Big Tex T/A...
2025 Swict 84in Bucket Skid Steer Attachment (A49346)
2025 Swict 84in...
