580D CASE STEERING
   / 580D CASE STEERING #11
You can do that, but air normally will be expelled after a couple of cycles.
   / 580D CASE STEERING #12
I'll say it again:
The hydraulic pump on the 580D is divided into two sections with a common inlet.
One section works the steering, the other section works the loader and backhoe functions.
(See attached diagram)
They never built a 580D without powersteering.
Check your steering pressure. If you have sufficient pressure and flow from the power steering pump, then you must have mechanical binding, i.e. king pins and/or bearings.
Mark
x 2.......What the OP'r is calling a "Steering Pump" is actually a steering valve to distribute oil..........
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
UNUSED CFG Industrial MX50R Mini Excavator (A47384)
UNUSED CFG...
2015 Jeep Compass Latitude SUV (A50324)
2015 Jeep Compass...
